94 XP 657x oil leak
CergizansAuto
94 XP 657x oil leak from crankshaft seal
Hello everyone, I'm new here but have found this site to be quite helpful. Here comes my question. I have a 94 XP that I rebuilt the top end on last year. Ski ran great all season, winterized it, started it up this year and ran great first few days, then would not start. It has an intermittent no spark condition and when it does spark, its weak. I have narrowed it down to a faulty stator, pulled the cover and flywheel and found some bare wires and some metal debris sticking to the magnets. What I also found was some oil in the housing, obviously from the front crank seal. I'm assuming this housing should be dry. The amount of oil was not excessive, but enough to cause a small puddle in the hull. My question is, what is involved in replacing this seal? Does the case have to be split? Also, are there factory timing marks on this case for stator replacement?
Thanks in advance.
A light film is ok, puddles mean the front seal is likely bad. You could possible replace just that seal, but the bottom end has a lot of hours on it already, so for the amount of time you'll spend, it might be better to just replace the whole crank or rebuild the whole motor. The outer seals leaking can cause air leaks and lean mixture, leading to burnt up top end.
If I'm understanding correctly, to replace the seal, you're saying the crank has to be removed. If thats the case, I agree. It would be best to rebuilt the unit.
