94 spx water line routing
cbr rob
New to Sea Doo's here and need some help...
So... New to me 94 spx... the water line routing seems kinda funky. The inlet line from the pump goes straight to the exhaust, but just before it gets there it tees off into two lines. They both terminate into the exhaust. The factory flush connector is still there and connected to the head. The other port on the head goes straight to the exhaust at the back (meets up with the main exhaust pipe).
Can someone post a picture of the cooling lines or show me a diagram on how the water lines are connected on this ski? It would be much appreciated...
-Rob
Sorry, don't have a pic handy... but that sounds right for the early skis.
1) The water comes from the pump, and splits, and connects to 2 points on the pipe.
2) A hose from the top of the pipe should go out the "Pee Hole."
3) The flush connector should be in line from the head, to the exhaust outlet
4) An outlet from the bottom of the exhaust manifold, will go to the exhaust outlet.
5) a possible second pee hole hose is connected to the front of the head.
6) a larger hose from the back of the head will go out a port in the rear of the hull.
Thanks for the reply, Dr. Honda.
We found that everything was just as it should be after pulling the house from the pump housing and sticking a hose in there. Started it up, started the water and everything was perfect.
Our concern stemmed from the fact that the exhaust was really hot and nothing coming from the pee hole when hooked up to the flush connector. With the water entering through the normal method (pump housing) the exhaust was nice and cool and water exited the pee hole just as it should.
-Rob
