Just try sucking in through the line as opposed to blowing. There should be no fuel in the line as it is a vent line only, but be careful of any fluid that may come out.
Even though I previously said this may be your problem, I am doubtful as once you primed your lines following snipe's advice, I would think you should have been able to pull fuel into the lines for a little while before not having air put back in caused enough of a vacuum to starve your fuel lines. I have never seen this happen first hand, so I don't know how quickly the effect would take place.
If you have the tools available, or don't mind running to an auto-parts store and laying down $40, I still think you should test your fuel systems pressure. You may have a leak in there somewhere.
Just to be sure...You don't have any fuel leaking and laying in the hull do you?
I pulled the return line off the carb and pulled the inlet tube off. I blow pretty hard through the return line and just got mostly air out of the inlet with a few squirts of gas. I shouldn't be getting any air through there should I? Any ideas
If your fuel lines were completely filled with gas, you should expect no air to come out. But, from the sounds of it, they
were filled with air.
You could, if you don't have or buy a pressure tester, hold or pinch close the inlet line while blowing in your return line. This will pressurize your system. Listen for air escaping from anywhere along your fuel system and tank. Preferrebly in a quiet environment! Pinch off your vent line so none of your pressurization escapes through the pressure relief or you may be fooled by hearing air escape out there. Also, soapy water will bubble where air leaks, so you could spray your lines and tank down to help. This certainly is not nearly as effective as having a pressure tester, but may help.
Also, I realize you have done this already, but make sure all your connections are correct. I think you said you found one that was messed up, but don't stop there and assume it was the only one.
This is the best advice I can give to you for now. Perhaps Snipe will chime in again with a more expert view on it.
