I just went thru this identical situation. So take your time and do this right. Go get 25' of 1/4 fuel line and a bunch of galvenized 1/4 clamps. Replace one fuel line at a time (I am slow that way!). There is a twist off fuel filter just above the fuel tank. Be careful and twist counter-clockwise and pull down at the same time. If it is too garbaged up, disconnect (one nut) and move it to where you can "persuade" it a little better. You can get a replacement by accessing the parts link on this web site (RivaMotorSports.com) is ultimately the supplier, but you get good discounts using this web as the doorway. Next, replace your fuel selector, some people "blow them out", I wasn't so lucky, I just replaced it. Now this is was the scary part for me, replace the carb fuel filter(s). Sorry don't know if you have one or two carbs, with Premium Membership here you can hit the service manuals or they are on other websites also. Order the right amount of small fuel filters for the carb(s) you have. REPLACE THEM!!! It took me about 1.5 hours to do this cause I usually stab myself with a screw driver! (Hint: clear your work area, lay out some white rags and use that as your carb filter replacement area...that way you won't lose parts and you can "group them" as you take them apart. Yes you have to take off a far amount of stuff to get the carb(s) out, take your time, it is easier than it looks. You will have to disconnect a cable or two, throttle and ???. Again take your time. I did all this in the last two weekends, I also did a bunch of other stuff. Replace your plugs too. The one thing I didn't do that I wished I had was pull the fuel baffle off the top of the fuel tank, siphon the gas out and clean the tank.....maybe this fall when the water reaches 44 degrees. So that should get you back in good sted to ride the rest of the season however long it maybe. Fuel filters are not hard to come by and carb rebuild kits are available (if you are really a masochist) are available from sbtontheweb.com
My ski soars after barely operating, just like you described.
Good luck!
