I've got the fuel lines swapped out on my problem ski, I just have the pulse line to go and to get into the fuel pump side of the carb and clean up the filter.
What is the best way to remove the single carb from a 94 GTS with the 587 engine. Is it to remove the whole rotary valve cover, or take the two mounting nuts off and pull the carb that way? If I pull the rotary valve cover will it also require disconnecting the oil pump?
