cruisertom
Ok I need a new impeller for my 93xp. The splines are gone causing a no forward movement condition. Anyway I have found a few possibilites on Craigslist. One is a Skat track impeller only that has 69 stamped on it. The other is a pump from a 97 and is part number 271000497 11/22 pitch. Mine should be 271000182 11/26 pitch. What is the difference in the pumps? They sent me pics and they look the same... What will the difference in prop pitches do to my ski? I imagine the stock 17" shaft will work on both? My pump needs a wear ring also. What would be the most reliable and cost effective solution? Thanks for any help and I have tried searching and found the part numbers but not sure about compatibility.
