93 GTX
Xquasa
Hello everyone just bought 2 93 GTX's and I'm trying to find the correct Carbon Ring/Bearing Seal Carrier for my Jet Skis, The hose was completely ripped off but it looks like there are Bearing Seal Carriers still on the drive shaft. Would greatly appreciate if anyone can point me in the right direction.
Double check the "thru hull fitting" that the carrier bearing hose attaches to. If the bearings are not greased and lock up or get tight the binding stress can get transmited into the hull fitting and damage it causing a hull leak. There is a fix for this so don't worry if the fitting is damaged, just double check to make sure you don't sink a machine once you get the bearings figured out.
One of the thru hulls was completely shredded the other one appears to be in good shape I ordered a metal one that is supposed to be a direct replacement and I haven't had a chance to figure out how to remove the old one yet
Here go.
