I bought my 92 seadoo xp 587, flushed the fuel tank, rebuilt carbs, new fuel lines, etc. It was a great ski all summer long. Then I went to start it recently and it was hydro-locked with oil. After doing some research it looked like my inner crank seals were bad so I decided to pull the engine and replace it or fix it. After I pulled the engine I noticed that there is alot of oil leaking from my rotary valve cover, specifically from the bottom most hole (See Picture). When the rotary valve cover is held up-right a steady steam of oil flows out of this small hole so im guessing this is actually the cause of my problems.
I spent quite a bit of time looking in the manual and online but cant find what would cause a steady stream of oil to flow from this hole.
Anyone have any ideas what could cause this?
Thanks alot for your help!
