sorry ,been busy
dam olde sneaky valve hiding on you!!
and yes, the marks are normal
the valve gets pushed and pulled against the two sides, the intake cover and the engine case , as the engine goes thru its cycles
intake and compression.
from what i see in your pics, things look ok
if you remove the rotary valve, mark its postion
because it needs to be timed correctly to the crank shaft
mud
