951 top end rebuild
cj22944
Who has the best top end rebuild kit and what oversized piston can I run with the original sleeves?
Also need carb kits, pump rebuild kit, 15/20 impeller
Looking for reliability and longevity. Maybe a bit more performance as it has only maxed out at 55mph since I've had it
2000 gtx limited
Best top end rebuild parts would be OEM, next Pro-X. You will not know what size to order until your machine shop measures the cylinders and can see how much material to remove to clean them up.
Carb kits and pump kits are easiest from OSD Seadoo.
You really aren't going to gain much performance without quite a bit of money spent at the cost of longevity. 55 mph is pretty good from a heavy 3 seater.
