Was out on the lake this weekend and doing more testing on my 97 challenger twin 787. At the begining of the day on saturday, i idled out of the no wake zone, pushed the throttles forward and both engines went up to 7k rpm without issue.... throttled back down and idled around for a little while and then, for the rest of the day, could not get one engine past 4800RPM. This is my second tank of fuel and have put in seafoam both times. I have owned the boat since december and the previous owner had the same issue. Got in the boat sunday morning and the boat performed much better. The one engine would run up to 5k rpm and as the boat got up on plane it would punch forward to 7krpm. The previous owner only had the boat out on the water about 3 times over a 2 year period. Compression is 150 on both cyls..... Do you guys think I need to go ahead and bite the bullet and rebuild the carbs (never done that before) or should I just continue to run seafoam thru the engine to see if the performance continues to improve?
Thanks!!
Scott
Thanks!!
Scott
