All,
I have had a reoccuring problem to where when I crank the engine in the water and advance the throttle, the engine revs to around 3k RPM and stays there for a little while. I pump the throttle and it makes no difference. eventually it comes back down but if I go to the carb and manually push aft on the linkage between the throttle, the engine immediately revs down. Any ideas as to where to start? This has been happening since I purchased and am looking for the easiest to start with first..... are there bolts that I can loosen to see if that helps?
As allways, thanks for the help!!
1997 seadoo challenger
