1997 GTX. Had a hesitation at 5000 rpm. Tried cleaning and adjusting the Raves, no luck. Messed with carb settings, no luck. Rebuilt the carbs (including seat and needle) and reset them back to factory settings, no luck. Replaced with updating rave valve housing (that does not have the slot per the TSB for 1997 rave valve caused hesitation at 5k rpm) and now it hardly wants to run. Acts like it isn't getting fuel. Would take off and briefly hit 6500-7k rpm, then wobble and slowly drop down to about 4500 rpm. After a few attempts at making rave adjustments on the water, I set them back to screwed all the way (how I had them before I changed the housings) and it wouldn't hardly run. When I left off the throttle, it quickly dropped to 800 rpm then stalled.
What on earth could have happened? I took it for a test drive in between rebuilding the carbs and replacing the rave housings and it was not doing this. The ONLY thing that changed was me replacing the rave housings. I think I'm going to start with pulling/changing plugs and pulling the carbs back off and making sure I have a clear return and supply lines. All fuel lines were replaced long before I owned it.
