Well according to your research, if a 1.5 needle and seat will give me all the flow I need, perhaps going back to a 1.5 will be better and I could get my pop off down to a 25 area where I think it would work better with the jets that are there.
Im thinking that once the transition occurs, or starts to occur, its too rich. Which is why the engine wont respond to the throttle as required. (the reason I dropped back the main jets) That way, the pop off could work properly with the air flow/vac as discussed with aftermarket FAs. If I leaned out the bottom end (somehow) I could get better snap from the engine.
I know your opinion if it was your machine, but in my case. What would you try first... going to a 1.5 NS and test pop off with OEM springs? From what you say, going to 1.5 NS and 70 pilots would clear up my issue. 2 jet sizes would make that much difference?
Whats the point in going bigger N/S if the stock one can flow as much anyways?
IF you think that a 1.5 will clear up my problem then Ill go buy them. To me, anything less ten 24 pop off is TOO low on these carbs with a 2.0 NS. If I should order stock low jets I will too. Remember, at the same time, today, other people are telling me that 75 lows and 2.0NS are the best thing going for 800 seadoo engine.
Soon Ill make the thing fuel injected with a aftermarket FI controller so I can tune it with a laptop. Wheres the headbang smiley?
