Waterluvr
Ok, here is some new info. When starting, the mag carb shoots out fuel from the carb meaning back out of the carb like pressure is forcing it outside the carb while the pto carb dosent deliver fuel. Could this be a timing problem? Could it be the rotary valve needs adjustment?
Sounds like the metering arm on the mag carb is wide open and the primary circuit is dumping all that fuel, you'd never see that much from the regulated circuit with the throttle plates closed.
When you rebuilt the top end you now have manifold pressure's back in spec and there's plenty of pull making it past the closed throttle plate ends and hitting the stainless air restrictor, that's working your high side and allowing the fuel pump to give up most of the volume it can push through to the mag carb high circuit.
Once you pull the stainless air restrictor out to have a look you're really stepping up air velocity and increasing the draw on the high side, even a timing issue wouldn't spit that much fuel back at you.
Look on the bright side, sounds like your fuel pump is working fine go find out why your needle is wide open.
