Hi everybody, I am just starting to research what parts I will need to swap a 717 into a 96 SP.  I am not 100% positive that it is an SP.  There are no decals on the ski and the exhaust looks like it could be an SPI/SPX according to the parts schematic. The schematic that I am referencing is (ENGINE SUPPORT W/ MUFLER AND SHORT BLOCK)  World of Powersports w/ SpeedSupplies.com''''''''s 1996 Sea Doo  It is not likely to be an SPX because the ski has the 587 in it.
So my first question is how can I identify the ski with the vin?
As I mentioned already the parts schematic shows that the SPI and the SPX have the same exhaust. Visually the exhaust looks like the 717 exhaust.
How can I positively identify the exhaust and if it will work on the 717?
I have a 717 that was pulled from a 97 Explorer. It has the bed plate, intake(single carb) and exhaust manifold, so I don't need to find those parts. I don't have the electronics. In my search I have read that I need a rev limiter from a 717. I have read that there are aftermarket rev limiters. Some people in threads that I have read, have been advised to pull the entire wiring harness from the doner ski.
Is the rev limiter a separate part or is it in the MPEM?
Can I just replace the Rev limiter or MPEM with just about any 717 rev limiter? Will it be plug and play if I can do that?
I have found that the 97 SP 717 has a rev limiter set at 5900 RPM and the 01-05 GTI 717 has the rev limiter set a 7100 RPM
Do I have any thing to gain by looking for the 7100 RPM rev limiter, or am I just asking for problems?
What am I missing? Throttle cable? Choke cable? Water box? Exhaust outlet? Will these parts need to be replaced also?
