580cc yellow and white motor whats the difference?
Tour991
What is the difference between thees two motors? are they interchangeable? are the stater's and mpem's the same can i combine parts from thees to motors to make one good motor?
thanks James
thanks James
well they don't have mpems...and the stators and flywheels are different. I do believe that you can use either engine with either ignitions but you need to swap the whole ignition out. Fly wheel, stator, and electrical box, needs to be complete.
yellow engine had all the "guts" inside/behind flywheel, where the hite motor, ebox, was on top of battery/left side of tank.
the cooling system is different as welll, the white, was more efficient.
