OK , hellow all I am new here, I have a 1989 SP and I put a basket case together. OK I blocked off all three oil injection lines to the motor, I ran across this site and noticed a thread that says you HAVE TO KEEP THE OIL LINES HOOKED UP except to the oil pump itself. Now I did not take it apart and pull any gear out, and luckely I have only started it for a couple of minutes. So what is the scoop, Do I have to hook the two lines back up, or take something out of the pump or both. Please be a little detailed on what needs to be done. I have no problem with pre mix. Thanks for the info.
