5 hrs on 2015 rxtx 260 and already fault code
overthetop
code c2101 the ibr is malfunctioning and i only have reverse, checked for loose wires nothing
this is ridicoulous any advice?
Check the IBR Module fuse. I believe it is 5 amps.....it may be 3. That fuse on mine was blown and I was experiencing the same symptom.....like it was stuck in gear. This is a different fuse from the IBR Motor fuse which is like 30 amp.
My IBR issue was a battery that was partially shorted internally. Would start the ski still, but had irregular voltage and the IBR did not like that.
Just checked fuses no go. Thanks though
