After running decent for the last few years I once again have an issue with not being able to run anything over 5,000 rpm. The forum has been a great resource in the past & wondered if you might come to my rescue again. Sequence of events & symptoms below.
I cleaned (but did not rebuild) the carbs and it ran great for a few outings. After about 3-4 good rides it started capping out at 5,000 rpm.
I then replaced the fuel selector switch, replaced the gray fuel vent lines with black fuel line (remainder of fuel lines had been changed ~8 years ago), and installed a new pressure relief valve as well as check valve for the fuel system. Still had the same issue.
Checked the voltage regulator - was only getting 12.7 volts when at 4,000-5,000 rpm. Replaced the regulator with an OEM part, now it gets to 12.8V. Read where it should be between 13.4-14.8.
So not sure what to do at this point. Cleaned the rave valves last year. Fixed a broken pickup coil in August of 2014. Any ideas on what would cause the symptoms described (including what would cause lower than expected voltage at the battery at 5,000 rpm with a new voltage regulator installed)?
Thanks so much for your help!
