68ragtop
Assembling the propulsion end of my 2002 GTX project.
I slid the driveshaft into position & was surprised how much Axial movement there is on the shaft. easily 1/2- 3/4" Is the carbon seal & bellows pressure the only thing that keeps the drive shaft forward into the PTO? I wanted to leave the c clip removed from the floating ring seal so I can run it on the hose for a longer time without heating it up, however with that clip removed, the shaft has what I would consider (from my 2-stroke ski experience) a lot of movement. The only thing that keeps it close is the oil sealing bearing in the PTO bellows. I am not too comfortable starting it this way & not sure why this much movement it there. Am I somehow missing something?
New rubber driveshaft bumper is installed on the PTO end of the shaft.
EDIT: My title of this post should say axial movement, Not radial. Sorry to confuse.....
68RT
68RT
