I have an '04 GTI and I think the post has gone bad. I was able to compare it to a known working post.
Problem: With the key off when I connect the battery the relay in the rear electrical box was energizing (clicking). and staying energized. From what I can find that relay turns on the MPEM and then checks the code in the key. Ski actually works fine but I was concerned that this would drain the battery. so I decided to fix it.
Luckily I have a matching ski to compare to, which helped to quickly diagnose the issue.
it appears there are 2 reed switched in this post, is that correct?
I am curious to know what they both do, anyone know?
Attached is some detail from testing a known working post.
