shucky
Just thought this may e of interest to some with the 4 techs they reckon it brings the 1500 cc up to the 300hp
This kit contains the following original Sea Doo OEM components
3 x Ignition Coils
3 x Coil Cap/Seal
3 x Coil connectors with pins and connector seals. (used to replace your original connectors)
3 x Coil Bolts
1 x Valve Cover
1 x Oil Fill Cap
1 x Oil Cap Pin
1 x Oil Cap Band
1 x Oil Pump Housing (replaces your original front oil pump housing with oil filter neck)
3 x Ignition Coils
3 x Coil Cap/Seal
3 x Coil Bolts
1 x Valve Cover
1 x Oil Fill Cap
1 x Oil Cap Pin
1 x Oil Cap Band
