glajos42
So I posted some information about the initial problems we had with the used 2004 GTX supercharged ski that we purchased.
We took it out and all was working great and then the ski had the problem where it wouldn't pump water out. It almost seems like something was sucked up into the impeller. I checked and nothing was there. When it does this I will hear a noise and vibration is coming from the back of the ski. The engine will rev up just fine during this but it just won't engage the impeller and move. I figured that the impeller and the shaft should always be spinning when it is started so I don't know why it would not move at this point.
I did look at the impeller before taking it out and it was fine as was the wear ring. The splines on the shaft to the impeller also looked fine.
So is there anything that I should look at on the shaft or is there something that can be adjusted on the clutch?
