Hi!
Here is my problem… I have a 2002 Gtx 155 that have some injector issue! The problem is that the injector #2 won’t pulse after start. In fact, when cranking with coils unplugged, all injectors are pulsing and seams to pulse evenly. But when all coils are plugged, as soon as the engine start, the injector #2 stop pulsing.
So I switched the injector with the #1 and the problem stay on cylinder #2
All fuses are good, I have a battery voltage on one wire and I have continuity between the injector connector and ECM connector on second wire.
Does anyone have an idea ? Like a cam sensor on crank sensor ? Like when the rpm reach more than « x » RPM the signal miss for cylinder #2 ?
Thanks !
Thanks !
