Howdy all. I have 23 hours on complete motor including new Hotrods crank. I experienced a massive loss in compression in the mag cyl. I took off the head and noticed rust and scoring in the pto side and massive scoring with no rust in the mag. took it to the boat mechanic. took top end off. mag piston was working the the sleeves and the rings were froze around the piston. Also new R&D head had pits on the mag dome also (go figure). Replaced top end with new jugs, pistons, rings, pins, oem head, gaskets, etc... before I started this back up
I replaced both carbs with new mikuni 40mm sbni and jetted mag to 147.5 and pto to 150 on the highs. Left everything else stock and 1.25 turns out on the low speed. Started out with 1 turn out on the mag and ok color and 2 turns out on the pto but still some brown (I now have 152.5 coming and will replace the 150 with it and then use the 150 in the mag thinking this will be good with the prok arrestors I have on.
First two hours on lake were fun but hard starting when in water and warm. Had to hold throttle wot when starting until it started to chug then would drop back to .25 and it would smooth out. Had some hesitation at half throttle but ¾ to wot was nice. Though I would adjust carbs more next time out.
Next time was today and after just an hour the boat started running strange and missing at different rpms. I took it slow back to the trailer and brought it home. I know have a 5 psi lower change on compression in the pto side and 10 psi lower compression change on the mag side.
What do you think of the following pics here.
