physicistkev
Started with not being able to get the boat on plane and lack of power. So I removed and cleaned the carbs several times. Ordered rebuild kit and fully rebuilt both carbs. Found my original issue was a clogged, forward carb filter, the one in the carb itself. This made the boat workable but far form great. I have emptied the fuel tank and cleaned it. Replaced all hoses with fuel injector 1/4 inch line. Which they were before, but I figured, what the heck. Disassembled and cleaned the fuel selector switch. Forward piston has 150psi and the aft has 148psi. Replaced both sparkplugs.
What I get is at WOT the engine is definitely misfiring. I find that about 3/5 or 3/4 throttle is about as high as I can go before it starts to misfire. There is also a delay with the throttle response, sometimes. Also, I have noticed that when executing hard left turns the engine RPM's drop a decent amount. Any ideas where to go from here?
Thanks,
Kevin
Thanks,
Kevin
