FlyingArrow
Hi all,
2007 230 Wake.
I've had some bilge problems - taking on water and then the pump burning fuses and ultimately quitting. I bought a portable pump to get me through the next day of vacation prior to trailering the boat to my dealer. Seems the leak is faster than I thought as overnight the bilge filled right up. I thought it was maybe coming from an external coolant line vs. the hull but it filled up overnight from being fully pumped out. I'm pumping it down now with the portable pump but concerned about how high the water was.
The water level was up to the battery tray. Just to the bottom of the battery which means the engines are half under water. Up to about the exhaust manifold (touching the bottom of the stainless shields at manifold exit) but well below the air intakes and below the throttle bodies.
Is there risk that any water could have been ingested elsewhere on the engine? Any risk in attempting a start once the water is out?
Any and all help/advice appreciated.
2007 230 Wake.
