Well, I finally finished witerizing by boat for the first time. Got a quick question for those that have been doing it for awhile.
I fogged the cylinders and the fuel rail. Pretty straight forward. Lubed the engine with spray to prevent rust.
Now here is where it gets interesting. I pulled the hoses to the super charger and let it drain. Not much water came out as I expected. Pulled the hose to the exhaust side and noticed a pretty good puddle of water under the boat after pouring the 10 oz of antifreeze into the hose. I guess I'm surprised by the water as I ran the boat dry for a few minutes and blew ( started engines and revved them) most if not all the water out. Is this normal ? It wasn't coming out the pump or exhaust port it appeared to be near the cooling plates on the hull.
I know I've got antifreeze in the intercooler and the exhasut manifold but was a little concerned about the water I saw on the ground. It was clear. New to the whole winterizing and just want to make sure it's protected. Let me know if I may have missed something or need to redo any part of the procedure called out here
