FOR SALE 2022 Triton Trailers
New 2022 Triton Trailers ELITE WCIVSBD Open Trailer Available at JetSkiMoto
If you're looking for a serious PWC trailer that’s built for long-term durability and heavy-duty performance, the 2022 Triton Trailers ELITE WCIVSBD Open Trailer available at JetSkiMoto is worth considering.
This model is part of Triton’s Elite Series, designed specifically for personal watercraft owners who tow frequently and demand structural strength, adjustability, and reliability. Unlike entry-level trailers that focus only on basic transport, the ELITE WCIVSBD is engineered for stability, proper hull support, and reduced maintenance over time.
Condition: New
Year: 2022
Make: Triton Trailers
Model: ELITE WCIVSBD
Category: Open Trailer
Stock Number:------
VIN: ----------------
Dealer:
JetSkiMoto
Heavy-Duty Fully Welded Aluminum Frame
The standout feature of the 2022 Triton ELITE WCIVSBD is its fully welded aluminum frame construction. Instead of relying on bolted connections, Triton uses continuous welds to create a rigid and unified structure. This design reduces frame flex during highway towing and improves long-term structural integrity.
The trailer also features custom aluminum extrusions and 3” x 3” scalloped frame rails. The scalloped design adds strength while keeping overall weight down, which helps maintain towing stability without sacrificing fuel efficiency.
Because it’s aluminum, corrosion resistance is significantly better compared to traditional steel frames a major advantage for saltwater riders.
Adjustable Fit for One-, Two-, or Three-Seat PWCs
One of the strongest advantages of this model is its versatility. Watercraft hull shapes vary between brands and seat configurations, so Triton integrates 6-foot adjustable bunks along with its Infinite Slide Adjust (ISA) bow stop system.
This means the trailer can properly accommodate:
Single-seat PWCs
Two-seat models
Three-seat personal watercraft
The bunks slide left to right and can be angled inward to cradle the hull correctly. This reduces pressure points during transport and minimizes hull stress on longer trips.
Open Design for Easier Maintenance
Because this is an open trailer configuration, inspection and rinsing are straightforward. Owners can easily wash down the frame after saltwater use, which helps extend overall lifespan and reduces corrosion buildup.
For riders who load and unload frequently, the open design also improves access and visibility during launching.
Why Consider Buying from JetSkiMoto?
JetSkiMoto offers this 2022 Triton trailer new and ready for immediate purchase. If you're actively searching to buy a 2022 Triton trailer, this ELITE WCIVSBD model provides a balance of strength, adjustability, and lightweight performance that suits both recreational and frequent riders.
For anyone upgrading from a basic steel trailer or needing reliable support for a newer PWC, this Elite Series model is built to handle long-distance towing with confidence.
