2020 GTX 230 not starting
rindress
Hey all,
I have a 2020 GTX 230 and am having an issue trying to get it to run. First, there was a dead battery. I replaced it with this one (Amazon.com) After replacing the batter still didn't want to crank. Discovered that the relay had the green crusties. So I replace it with one of these (Amazon.com: HIMARKLIF 4PCS Main Harness 30Amp Relays 5Pins 12V Compatible with 2008+ Sea-Doo GTI GTR GTS GTX RXP RXT Cruise Spark 900 Base 16/19 Sport 18/21 Fuel Pump Relay Replace# 278003828 G8V-RH-1C7T-R-DC12 : Automotive) Now it cranks and at first it started up. Ran really rough and I didn't want to keep it running out of the water so I stopped it. put it in the water and started a couple more times. Now it just cranks and doesn't start. While out of the water I did spray some carb cleaner in the intake by the throttle body. It fired right up then died. I figured it was a fuel issue. I removed the line from the fuel rail and the pump is working fine it fills a jar pretty quick.
At this point I'm thinking it's something up with the fuel injectors or whatever part of the ECM tells them to fire. Any pointers would be greatly appreciated. Is there some voltage I can look for on the injector connection to know it should be firing? Let me know if there is more information that would be useful to diagnose what is going on. BTW I forgot to mention I do not see any check engine light but at one point after trying a few times to start it the battery light came on and I saw the message "IBR Module Error". I assumed that was due to the multiple attempts at cranking since it did not show up at the beginning.
Thanks in advance,
Rindress
BTW I did read this post 2020 230 GTX, Will crank but not start, no error codes. and while it's very similar I didn't find any information about the electrical signal to the injectors.
Sounds like you have a fuel issue. Check your fuel pressure with a gauge. If the pressure is in spec, you'll want to check the injector control signal from the ECU.
Pull the fuel rail and watch the injectors spray pattern while cranking. Should also change your spark plugs.
When you do the test, put each injector in a small bottle, so as not to get fuel everywhere and set your machine on fire.
And check your fuel pressure.
Thanks so much for the video. Love his vids. Anyway I've been away for a bit and I'll be getting back to this soon. I'll have a look through the service manual for the pressure. I honestly think the injectors are not opening because it fires right up with a squirt down the intake.
Good point about the plugs. To be on the safe side I'll pull them as well and take a look at them. Since I had fuel entering the rail with the supply line detached I am thinking it's the injectors not firing. I appreciate the post.
Thanks for the input. I should be able to get back to looking at this very soon. Good point about the fuel. It's not so much the fuel but the vapors....
Okay so it took a while for me to get back to this. I appreciate all the feedback. So I ended up taking the fuel rail off and first checking that the injectors were firing. They were and I was collecting the output. It didn't look right to me. So I removed one of the injectors and then had the fuel pump run. Lots of fuel, about 8 oz at a time. The fuel was HORRIBLE and 95% water. I have no idea how that happened but I then drained the tank, yes all 7 gallons :( Not sure if there was a better way but I kept running the fuel pump in spurts until I got it emptied. Next I put good fuel in there and sure enough it started right up. So in essence the main problem was the relay for the fuel pump was corroded. That was replaced but then an issue with the bad fuel really through me for a loop. Goes to show you just go through the steps 1 at a time. Thanks again for all the advice. Hopefully this might help someone else some day.
