Hi all,
I posted this in another forum before finding this one that appears to be more active.
While riding the other day one of my rub rails popped off during what I'd call normal riding. It didn't come entirely off the ski, but was not attached as it should have been. I really didn't want to wait for a dealer to help me fix something that seems like a simple repair, they'd likely take time away from my ability to ride and BRP in my experience does everything they can to avoid helping to fix things under warranty anyway.
So I get home and take things apart to see what's going on. There is a channel at the bottom of the rub rail trim that appears to be made to fit around a piece of the hull and then snap in a the top, should be simple. Well there appears to be a lot of extra epoxy in the area where the bottom of this rub rail is supposed to go that thickens this part of the hull enough that the rub rail doesn't actually attach to the hull as snugly at it seemingly should. See the pictures attached of section where you can see the bottom of the rub rail doesn't actually fit around the hull because of this epoxy (grey stuff) and also a section where I removed epoxy so that the rail fits as it seems it should.
Any dealers or experts out there know:
1. Is this epoxy supposed to be cleaned up at time of manufacture?
2. Is rub rail installation done during dealer prep and they are supposed to clean up this epoxy? (should a dealer notice this during prep?)
3. Is it fine for the rail to not quite fit around the hull and this is how it's supposed to be?
Thanks!
Don
Thanks!
Don
