Ckrawiec
OK...quick story......went out move the 2017 Spark 2UP (floating at my dock). It was started and launched 2 weeks prior with no issues.
Pressed the Start button to wake her up....NOTHING.....dead.....should have gotten the WELCOME message on the center guage. Battery is good, all fuses checked out.
Problem....NO electric power (so it would seem).....checked Start/Stop button (good continuity, no problem there), checked wiring harness connectors for corrosion (all good).
Simple solution......the RELAY [OMRON #13502750] plugged into the fuse box was faulty.....ordered 2 new ones on Amazon, got in less than 24 hours.....plugged a new one in and all is well. NOTE....this relay is a fairly common automotive part, you can probably find it at Autozone or elsewhere.
