Tom Riedinger
The ski starts up and idles smoothly, when on water it sounds normal but only goes half speed (only ran it 2 minutes). Getting good spark to all cylinders, but when I unplug the coil for cyl. 2 or 3 while idling the motor stops instantly. When I unplug the coil for #1 cyl. there is no change in rpm or motor sound. so I'm not getting fuel to #1 cyl. Cleaned and tested the injectors and they are good. All plugs and coils are good. I even checked the connections from the ECU plug to the injectors and all OK. Does anyone out there have any suggestions?
