2015 gtx260 ltd is problem - 145 hours
ermant
There are 2015 model Sea-Doo gtx 260 is. When I give full throttle, it stays between 6000-6500 rpm and it doesn't go. what do you think is the problem?
I’m having the same problem (I have the exact same ski) but mine stopped running mid-ride.
I was cruising at 5K rpm in Touring mode and heard a (minor) noise that sounded like I sucked up a stick or something. A minute later it wouldn’t rev above that 5K rpm so I switched to Sport mode and tried to hammer the throttle. Still no acceleration, but then it slowly went down to idle and stalled out.
Will try to crank all day but won’t start.
Clean impeller and good battery.
No codes.
My guess is a fuel pump, any thoughts??
