I've run out of things to check, would love the community's advice. MY RXT-X has a loss of power and caps out around 5,200 rpm. It revs slower than normal but once it hits 5,200 rpm that's about it until enough coolant has gone out of the system (about 10 minutes of riding), then it'll surge to 8,000 on/off, after 2-3 more minutes, it runs super strong without surging. Next, I see the temp get too high and I have lost 1/2 gallon coolant, that's the end of the ride. This is repeatable, it's the third time it's happened.
I thought the symptoms indicate the coolant getting into the combustion cycle but it's not the inter-cooler, that's dry (cold or full temp). The hull seems to be where the coolant ends up. I cannot figure out how low coolant is changing the performance. Any ideas?
- New plugs
- Fresh fuel
- New fuel pump assembly
- cleaned all injectors
- new coils
- good spark
- plugs are a nice brown
- runs smooth just slow
- not fault codes or engine light
- inter-cooler dry, both sides
- Pressure tested coolant system - holds 10 psi for 30 minutes
- Compression 105 all cylinders, warm or cold
- squeeze the supercharge discharge hose and it opens my hand as I rev the throttle
- out of water, I can get it to rev to 8K but it pauses near 5,200 then bursts strong to 8K while pulling the supercharger intake hose about 2"
