675 Triple
I have a pair of 2013 SeaDoo GTX155s (suspension models). I'm trying to change the oil but the filter is tucked away to the rear of the engine compartment. I can post pictures if necessary. I have a short ratchet with the proper torx socket but the working space is very limited. For those who have changed the oil on this model, do I need to remove the plastic engine cover (which also houses the coolant reservoir and air box) to get more access? or can the filer be removed without taking anything else off?
Thanks.
Thanks.
