2013 GTI SE - maintenance required on display
Knugget
Just started my sea doo for first time this year.. took it out and it was going about 15-20 mph UNDER what it normally does. Sometimes it would speed up and then other times stay that same low speed. Any ideas? Spark plugs? Only says MAINTENANCE REQUIRED and shows a wrench at the top.
Did it end you try switching to sport mode? Mine was doing this on Monday, it wouldn’t go full speed for about 2-3 minutes then it was good to go still not sure about it tho. First ride of year and just got oil change
Any details back on this? Second day with maintenance message.
Always start with replacing spark plugs. Hopefully that resolves it. I am not aware of a maintenance message limiting performance. I think you will find fresh plugs get you back up and running. Address any other maintenance your machine requires ASAP. Make sure your oil level is good.
