2012 Challenger 230 / 520
pretex
Does anyone have any recommendations on aftermarket impellers for a twin 260hp Challenger? I believe the pitch is different for port and starboard engines. Also, any opinion on the factory wear rings or to recommend going to stainless? Pros and cons?
Thanks,
Pretex
Hey Pretex,
Don’t have info on impellers, just curious with the 520, what are you hoping to get by changing?
Regarding the rings. I stick with oem for the wear rings. Decision on stainless depends on where you boat, how’s the water? Lots of debris etc. are you going thru wear rings right now? If yes and you switch you’re likely going to wear out impeller instead. ~Rick
Just prepping to do some work at end of the season to the boat. I get some cavitation on the Starboard engine if I really stick the throttle, have to back off a little then it stops. I suspect either the impeller and or wear ring. Yes, we get lots of debris lately in our lake, they keep releasing water upstream which brings a lot of bark, logs, etc.. I have also seen some wear rings from the Impeller store that aren't plastic, but their composite version. Thoughts?
PRO Heavy Duty Sea Doo Wear Ring RXP/ RXT/GTX /Wake/GTR 215 GTX LTD 230 Wake Pro 230 & boat 159mm
5.0
Store/WaterCraft Parts/Pump/Wear Rings
SKU 3501
$35.99
ON SALE
$72.00 Save 50%
In stock
Add to Bag
Product Details
Our Heavy Duty Inlandjet Sea Doo wear ring upgrade wear ring made from acetal homopolymer which offers higher tensile strength, stiffness, creep and fatigue resistance, and has significantly higher impact resistance material which also reduces friction and in turn makes smoother water flow. A stronger wear ring that last longer is another benefit over plastic. Strongest on the market. Guaranteed not to crack. This wearring is precision cut and machined for max performance and fit. That sets us apart from the other Rings on the market 0460142. 2yr warranty from manufacture defects. Our Sea Doo wear ring fits GTR 215 12-16, GTX 215 07-17, GTS 90 GTI90 GTi 900 GTS 900 GTi Se 900 GTX ltd 06-07, GTX ltd 215 2007-16, GTX LTD 230 GTX LTD IS 255 09, GTX 260 07-17, GTX LTD IS 260 2010-16, GTX LTD S/C 05 (only 267000105 pump), RXP & RXT 215 05-09, RXP S/C 04, RXP X 255 & 260 2008-16, RXT 05-17, Rxp & RXT 215 2005-10, RXT IS 255 & 260 2009-16, RXT X 255 2008, RXT-X 260 2014-16, Wake 215 08, Wake Pro 215 2009-16 Wake Pro 230. Replaces OEM # 267-000-105 & 267-000-372 & 267-000-338 OR 159MM PUMP. BOATS: BRP 4-TEC 07-up, 205 UTOPIA SE 430 08, UTOPIA SE 215 09, 180 CHALLANGER 07-11, CHALLENGER 230 SE 215 07-12, Challenger 230 SE 430 08-11. CHALLENGER SR 07, 230 Challenger WAKE 430 08, Challenger SE 510 2010 -11, 210 Challenger SE 2x215 2012, 230 Challenger SE 2x215 2012, 230 Challenger SE 2x260 2012, Speedster 150 215 2008, SPEEDSTER 200 215 2007-09, Speedster Wake 215 2007-09, 230 Wake 215 09, 230 Wake 255 09,210 Wake 430 2010-11, 230 Wake 430 2010-11, 230 wake SE 510 10-11, 150 Speedster 215 08-09, 150 Speedster 255 09-11, 200 Speedster 430 08, Speedster Wake 430 08, 200 Speedster 510 2010-11, Islandia SE 450 08, islandia SE 215 09, (2012 2x215 2x260 1x260) 2012 Seadoo Challenger 210S 260 2010-12 180 Challenger 255 SE/SP 2012 150 Speedster 260 2011-10 150 Speedster 255 Replaces OEM # 267000105 & 267000372, 267000338 OR 159MM PUMP.
5.0​
So couple things, just my thoughts, Honestly I’d steer clear of the cheapos, I took a shot and ordered a couple from different place and they were out of round and not even the same sizes.
Keep in mind if you’re in a water with a lot of debris you have to think something is gonna wear down. If you go with oem type wear ring, it’ll be the thing to wear out. If you go heavy duty or stainless something else has to give, ie impeller.
I’m in heavy debris water on river, I just changed my rings, got 4 years out of them. One other thing is to do pump maintenance. New bearings etc. the combo for me puts you back in the seat when I throttle up. Didn’t notice any cavitation,that I had last season, while towing with a full boat last Sunday.​
