Hi guys, so its my first post and unfortunately its due to a problem I have with a bone stock 2011 RXT-X aS 260 with about 35 hours on it. Its been running like a champ aside from this one issue.
I have a very rare, or so it seems, issue with the SeaDoo at full speed and WOT. When I am doing about 65+ MPH at WOT, the SeaDoo will suddenly show a random speed reading on the speedometer of 80 - 100 MPH, etc.. This instantly causes the limiter to kick in, cuts throttle, and almost throws me off, as its very sudden and unexpected. Over the last couple of years and about 20 hours on the water, this issue has occurred about 10 times. The doo does not throw any codes, and the GPS symbol is solid green, from what I recall. The entire duration of this lasts about 1 - 2 seconds and then everything goes back to normal. By the way, I have never had this happen at lower speed, only near the limiter range and at WOT. Its almost like I am going too fast for it to get an accurate speed reading.
I went ahead and called 3 different SeaDoo dealer in my area. No one has ever heard of this issue. I have B.E.S.T. extended warranty, but all state that they need to reproduce the issue to have it covered under warranty. I think the chances of them being able to reproduce it are close to 0%. I don't want to waste my money and time, so I wanted to pick your brains and see if someone has had a similar issue or may know more details about this problem. The more ammo I got to work with, the easier it will be to have this repaired, or so I hope. By the way, do you guys know if BEST covers the GPS/speedo or am I going to get some run around regarding that? Do they cover both labour and parts, or is it parts only and I have to pay for labour?
Thanks for any help!
RadVad
RadVad
