Sam Dudley
Hi all,
So I recently had an issue with the T.O.P.S. sensor (fault code 1502) checked the resistance across it and fair enough it was out of spec (25 ohms instead of approximately 35 when upright). This has now been replaced and it still will not start.
The relay is buzzing when you first put the key in (yes I have checked all earths and they are fine) once the buzzing goes away the ski does nothing for a minute. Then does 2 very short beeps, one long beep, a pause and then the 3 starting beeps. Hit the start button, hear the start solenoid switch over but that's where the action stops. I have not seen any fault codes come up.
Also when I first put the key in no immediate beeps, have to wait a couple of minutes for the sequence to commence.
Does anyone have an idea what I can check next? Take the battery off it for 12 hrs and hopefully the ECM resets itself?
Let me know what you guys think.
Thanks in advance.
Thanks in advance.
