dvhouten
I just bought a 2011 GTX 260 and it spent the last 2 years sitting on a skid in the lake without a cover. The battery was 4 inches under water. after draining it, I took it apart, pulled off covers and unplugged all the plugs I could reach. After drying it out for a day and putting in new gas and plugs, it started right up. We ran it for a couple days and then trailered it. The next weekend I come out and it won't start. The cluster won't even light up. I've pulled it apart again and used contact cleaner on everything electrical. All the fuses are good and I checked the ground from the negative post to the frame. I cleaned the starter solenoid and it will turn the motor if I jump the terminals.
I'm only getting 10 volts to the main relay fuse F8 (main fuse supply) but if I jump across it directly from the battery it still won't respond. I'm getting 7.5 volts to F4 (fuse to gauge), and less than a volt to F3 (fuse for start/stop switch). Even though I knew it wouldn't start until the dash responds, I tried both keys.
Any suggestions on what to test next? Maybe voltage regulator?
Thanks,
David
Thanks,
David
