BillyTequila
Just purchased a super clean 2011 gtx215. 80 fresh water hours.
Dropped it in yesterday, she ran like a raped ape for about an hour.
Shut it off normally. Tried to restart but can’t get engine to turn over.
Symptoms =
Normal gauge pre-start process
Two beeps
Push start button, gauges go blank like starter is using all power.
Relay near battery clicks.
Something in engine compartment clicks ( assuming solenoid )
But no turn over.
Here’s what I know / have done so far.
Battery fully charged, cleaned terminals.
Pulled off intake grate. No debris visible.
With vice-grip can turn shaft and can feel compression stroke as I work it through around 90 degrees.
The guages say “ maintenance required” but that’s not new. Was there when I took delivery and all day yesterday when it was starting.
Fault code says “no active fault codes”
Help.
Symptoms =
Two beeps
But no turn over.
Help.
