Spyder7892
Guys,
I have a 2010 Seadoo Challenger 210 430hp and I was wondering if there is a way to check and see if the intercooler is leaking? I have seen videos of the guys checking the externally mounted units but not much is being said about the ones that are mounted inside the intake manifold. I have been throwing some codes associated with the TB assembly and from everything I am reading this can be related to the IC leaking water (even though the IC on mine is after the TB?). I have a new TB coming but while I have it apart is there anything I can easily do to check and see if the IC is leaking? I do not see any milky oil that suggest that I have been ingesting water but I would like to check if possible before this happens.
Thanks!
Thanks!
