First off, greetings all!   This forum has been great in answering my questions while looking for the right Sea-Doo, so, thanks!
I've finally purchased my 2010 GTX 155 and will be picking it up and putting it in the water on Friday. Realllly looking forward to it, it's been a long time coming.
My question is regarding proper break-in procedures. I'd been told "just follow the owner's manual exactly" but, quite frankly, the owner's manual is quite lacking on info for break-in.
To quote them:
I read on here (can't find the post) the following:
Also, any other tips for a first-time owner? I've done the whole boating safety course (required by law here), gotten my lines and fenders, and all sorts of other equipment, got a portable VHF, and know the waters where I'll be riding pretty well thanks to my friend who has a boat there. I'm just wondering if there are any other "typical first-timer mistakes" that I should watch out for.
This is all fresh-water, and will be kept on a raised platform out of the water at the marina. Any specific post-ride procedures that need to be done (flush, etc.)?
Thanks in advance, and for all the great info on these forums.
To quote them:
... pretty brief.During this period, maximum throttle should not exceed 1/2 to 3/4 opening. However, brief full acceleration and speed variations contribute to a good break-in.
This explanation seems MUCH more useful, and I'm wondering your opinions. I want to make sure I get the break-in right, so I can enjoy this for years to come and can avoid any warranty hassles.Break in Process for 4-stroke SeaDoo
Before each ride, do a visual inspection of Oil level, all hoses an for any loose clamps, brackets etc.
Warm up the engine completely. first(in water) (off plane for 2-3 minutes).
Take it easy for the first hr, no more than 4000-5000 rpm.
Vary throttle for first two hrs, no more than 5000 rpm. Don't stay at one rpm for long periods. Only use 66% max throttle.
Let ski completely cool, down then repeat (this de-stresses the block).
After 3-4 hrs, short bursts of WOT are good, but don't go to top speed, just accelerate, then back off to 5000 rpm then repeat.
After 6 hrs, go to WOT for no more than 10 seconds.
After 7 hrs, your pretty much all done, ride it as you like but just refrain from long term WOT runs (more than 30 seconds).
10 hrs, change the oil.
As for the learning key, NO, use the normal key.
If the growling noise is between 4500 and 5000 rpm, its normal.
