AlbertaDooGuy
So...First time out after storing the boat for the winter.
I gave everything a once over before heading to the lake, everything looked good. Coolant and Oil levels all normal. Plugs and air filter all checked out ok as well.
Anyhow, got the boat out on the lake and everything seemed ok. Loaded up and started leaving the dock area and sucked something into the impeller. It shook the boat. I blipped the throttle a couple times and that seemed to have cleaned it out as the vibration went away.
Left the no wake are and started laying into the boat. I noticed it felt pretty low on power and it wouldn't pull beyond 6000rpm. It was steady at 4000rpm but as soon as I gave it more throttle it would surge from 4000 to 6000 and wouldn't really gain any speed. It also smelled like it was running very rich (Black soot around the exhaust exit)
Limped the boat back to the dock and started checking things out. Plugs looked fine. Coolant level looked normal. As soon as I pulled the oil dipstick I found milky oil and it was well beyond the fell level.
I sucked the oil out today and ran 5 litres of oil through it while removing it as I went. It's still fairly milky and I'm at a loss as to where the water/coolant may be coming from.
Has anyone encountered a similar issue with their 4-Tec? Any and all help is much appreciated.
