Got the boat out of storage and the coolant reservoir was completely empty. I’m concerned there’s a leak somewhere. Changed the oil and there’s no coolant in the oil, so maybe intercooler?
You will need to do a pressure leak down test on the cooling system, if it fails you will need to trace the problem.
It could be just a loose hose, did you see any coolant under the engine?
