dbcycleparts
I recently purchased a 2009 Seadoo iS RXT255. The machine runs fine. But I can not get the left side handlebar VTS switch (both up and down) and the cruise button to activate. I have replaced the left switch module and it still does not work. I also tested the switch on the cruise and it is functioning when depressed. The VTS does function, but only by going through the Mode button on the right side and using the up & down buttons on the right side of the handlebar, so I know the actual VTS does work, and the motor and rear module are not bad. I have also tested the switch wires up to the cluster and they have continuity from the switches to the cluster. I have see some old locked down threads on this, but never a reply with what the actual cause of the non function on the cruise and vts buttons was? Has anybody had this occur and what was the fix for it. It appears all the wires from the cruise and the vts buttons run into the dash cluster. Any help would be appreciated. Thanks.
