Robert14709speedster
Please help !! 18hrs. on the boat 215hp rotax 2009 Challenger180. If I roll the throttle on slowly there are no issues I get up to plane and top out at about 32mph. If I punch the thing a bit to pull up a wake boarder it cavitates like crazy end then gets going. Once its going were good.
I got under and look in the grate and everything looks good but one thing. There is a blavk seal that is sitting between two pieces just ahead of the impeller. it looks to be squeezing out a bit and a little worn in spots.
Should this seal be flush and tight all the way around ???
Are there any other things I can look for or ask for at the shop when it goes in cause this must be warrenty 18hrs. right ????
It was in last week and they said the wear ring was good but this weekend it got worse.
How about a stainless impeller any suggestions ????
Thank you,
Thank you,
