Jobondur
New to the forum and there is a ton of great info here.
I bought a project ski for what seemed like a great price. The owner said it took on water but he got it back to the dock before it got into the engine. He said he thought it was the thru-hull fitting and everything else was fine. So I got it back to my house and the thru-hull was fine but needed a new carbon seal, so I replaced that. Also rebuilt the jet pump while I had it off and replaced the wear ring. Pulled the plugs before cranking and there was water in the cylinders. I turned it over and blew as much water out of the cylinders as I could and then heavily dosed with fogging oil. Pulled the intake manifold off and dumped out a good amount of brackish water. Pulled the supercharger and that was full of water too. Then without re-installing the supercharger or intake manifold or reconnecting any of the electrical connections except for the ECU, I did a compression test. Cylinders 1 and 3 are at 60 psi and cylinder 2 is at 20 psi. Obviously none of the cylinders are where they need to be. My question is does the intake manifold or supercharger or other connections/sensors need to be reinstalled to do the compression test properly?
Right now I'm getting myself ready to pull the engine out of the ski and pull it apart. I'm thinking corrosion in the cylinders and rings. I can tell the tops of the valves look pretty bad and am pretty sure the ski sat for at least a month before the water was removed. Is there anything else I should do before I pull the engine? Attached is a pic of the top of the valves taken after the intake manifold was pulled off. I don't have a borescope to look down inside the cylinders.
Any help is greatly appreciated....
